TractorLinks.com
Show Parts for Model:
Re: TO-30 Questions.
Richard L
04-11-2013 04:51:12
No the front rims and rear rims are not correct for the TO 30. Those front rims look like the rims many of the trailer mfg. co. use. The original front rims had 12 holes so you could install the rims on the hub either way if you wanted to change the width for different crops.
Del Huebner
04-11-2013 05:43:34
 Re: TO-30 Questions. in reply to Richard L, 04-11-2013 04:51:12
Will the rims from an 8N Ford fit on the TO-30 front and rear hubs?
Jason S.
04-11-2013 06:19:54
 Re: TO-30 Questions. in reply to Del Huebner, 04-11-2013 05:43:34
Yes rims from an 8N will fit both front and rear. The only difference is the valve stem holes are on opposite sides on the rear rims and Ferguson and Ford used different mounting bolts for the outer rims but they will work. Ford used a carriage bolt while Ferguson used a bolt that had two flats on the head so you could hold the bolt with the Ferguson wrench if you needed to.As a matter of fact, the solid center rims that the N series came with are no longer available and the end up being replaced with the scalled style center rim that Ferguson used.
