FE-35 loose transmission shift lever
Bart CA
The shift lever is loose and rotates on its base.
I looked in the parts list explosed view...
there is a pin at the base of the shifter that I suspect to be broken. There is not enough detail on the image.
Is it possible to replace the pin without removing the transmission cover ?
The tractor is at our summer place I would like to bring the proper tools and parts when I go there next time.
Thanks In advance.
Bart
This picture may help you. The new pin is splined at one end to lock in the housing. You will need a flat ended punch to drift the old pin out. Sometimes the new pin can be used to drive out the old pin, but if yours is broken it may take a bit of jiggling about to get the holes lined up. Check also that the cup is tight in the housing, this is held tight by a locknut/collar that has to be tightened with a 'C' wrench.
Sam
Samn, Many thanks for your reply and for the explanation and the photo.
Greatly appreciated !!!
Bart
