TractorLinks.com
Show Parts for Model:
Re: Building the hay rake that Harry didn't
Tony in Mass.
04-07-2013 10:29:00
I got a reason for ya. Too much work! Is your hay so thick and lush you don't want to use the tin funnel flaps and narrow the swath a foot? Where I was haying, it wouldn't dry as good as letting it all fly out the rollers as it wanted. BUT... I had a 9 foot haybine, with an 8 foot rake... and it all worked well together. When I was young and inoccent, the neighbor, who worked at a local dealership, told me the IH 1109's were the best, cornered well, simple, great rollers, easy and cheap to repair, and my little 40-45 horse AC's powered it just fine- and the antique rake worked with it like a pair of new machines. So... a labor saving idea here? Go buy a 9 foot mower! Disc plows... ground drive rakes.... i gotta get outta here....
Jason S.
04-07-2013 14:09:50
 Re: Building the hay rake that Harry didn't in reply to Tony in Mass., 04-07-2013 10:29:00
I"ve got it set as to throw as narrow of a windrow as possible out the back of the haybine. The rake isn"t a ground drive, it"s a 3pt hitch pto rake. I have never used a ground drive rake. I"ve never even considered it...I"ve got too many corners to rake. I just always thought you could do a neater and cleaner job using a 3pt rake.
Tony in Mass.
04-07-2013 18:11:25
 Re: Building the hay rake that Harry didn't in reply to Jason S., 04-07-2013 14:09:50
Agh, Jason, I am confusing myself again. There are 2 'ground drives' out there huh? One powered by tires, the other 'ground' pto postition on the fergie transmissions... Or does this one go at 540rpm? I don't want one of those, I want a ground speed pto one... someday...
Jason S.
04-07-2013 18:19:17
 Re: Building the hay rake that Harry didn't in reply to Tony in Mass., 04-07-2013 18:11:25
It is a ground speed pto one. Oddly enough though, I have used it behind my 175 on ground speed and the ground speed on it is much slower than my TO20. I was running the 175 in first or second gear high range and it was too slow. I ended up running it in 1st high on live power idling the engine and it still turned it slower than the 20 does in 3rd gear.
Tony in Mass.
04-07-2013 18:30:18
 Re: Building the hay rake that Harry didn't in reply to Jason S., 04-07-2013 18:19:17
Hum. Since the speed of the rake goes by ...rotation of the tires...right? You got super tall tires on the 175? And low profiles on the 20? I always thought they would be the cat's pajamas... but maybe that's why they dropped the line?
Jason S.
04-07-2013 18:44:01
 Re: Building the hay rake that Harry didn't in reply to Tony in Mass., 04-07-2013 18:30:18
16.9x28 on the 175,11.2x28 on the TO20. I know there would be some difference but we are talking extreme differences between the two in ground speed. I used to think that there was a difference in the ground speed between a TO20 and TO30 because both rakes I have now turn faster than the D-EO-20 that I grew up with. That one was a later model that didn't have the idler on the belt, but I found out that there were a couple of pulley sizes used on those rakes. One of the pulleys was for use behind a 9N or 2N so I imagine since the rake would be used in 2nd gear most of the time on those 3 speeds that the pulley was made to slow the rake down. I figure that's what we had because it did turn slower than the ones I have now behind a a TO30.
