Well, until someone else reads this and ads to the post... which engine is this? Std or Cont? Are you needing pics of the inside of the gov or the linkages outside? I can dig up or take pics of a Z129 linkage if that helps.
Sorry, I thought all Tea"s were standard motors. The outside linkage pic would be great. I had it apart two years ago when trying to address a prestone in oil problem and had no issue at that time. Getting older the memory must be failing. My manual does not show the set up clearly. As for the prestone in the oil, someone had butchered a sleeve gasket repair with silicone prior to me buying. Problem is now resolved with the proper parts, thanks to Easy Tractor in Brampton Ontario.
Don
Hey Tony, finally figured it out. Had the arm on upside down, pin broke when I was taking it of. Thanks for your efforts. Pic for anyone who may need it.
Don
Governor linkage TEA 20
Good news for once! Yep, it looks more or less like a z129 linkage. A lot of those springs snap and just hang there, or yeah, ya forget to re-hook it... always the last place to look for governor troubles, but right under our noses!. So it all works OK now?
