Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: whats next
Tony in Mass.
04-07-2013 07:50:31
Yeah, water in the oil is more ...omminus? than oil in water. I do that by accident all the time, grabbing the wrong funnel, using an oily jug to drain antifreeze into... So I have to much oil? Good easy start is to just drain it all into a CLEAN pan...let it settle, and do detective work from there. Like mentioned here earlier, might be a time to also drain the oil- into a clean DRY pan... and look for water that settles on the bottom. And as mentioned... let it drain out for a day or two if possible, with a small dry pan under the drain hole...if water or antifreeze is dribbling down over/after a couple days...THEN you have a problem... along with nearly every other Z129 out here...
04-07-2013 09:59:47
 Re: whats next in reply to Tony in Mass., 04-07-2013 07:50:31
it is a z134. is that any better?
Tony in Mass.
04-07-2013 18:14:26
 Re: whats next in reply to buster-cur, 04-07-2013 09:59:47
Yes, much better, far less likely to crack between the webs. I'm interested to see what you find out about it. good luck.
