Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TED20 Oil supply to rocker shaft
Jason S.
04-05-2013 16:59:00
I would drop the pan and check the pickup on the oil pump. Make sure it isn"t loose and sucking air instead of oil. Check the relief valve on the pump. See if it is stuck. I"m not real familiar with the standard engines but there are several other engines out there that will not pump oil unless the oil pump has been primed. Might be worth trying unless the pump is worn out. Have you blown air thru the passages in the filter housing?
