Just a reminder if you own an old TO-35.
when you change the oil filter this spring, there is a washer and spring inside the oil filter housing.
This spring and washer will fall out most every time when you dump the old oil filter out into the used oil can or dumpster.
if your oil filter housing does not have the spring and washer inside the filter first before the oil filter goes on the shaft, the oil filter will just flow around inside the canister..
the oil will travel around the filter and not be filtered.
just a heads up. but I am sure most everyone is aware of that.
