85mm to 87mm kit source
shackwrrr
New User
Is there a kit like this available in US?
http://www.ebay.com.au/itm/MDEKM28-Engine-Rebuild-Kit-Massey-Ferguson-TEA20-Tractor-Converts-85mm-to-87mm-/261186476102?pt=AU_HeavyMachineryParts&hash=item3ccfed5846&_uhb=1#ht_2385wt_1216
Looking to overhaul our TEA-20 and would like to upsize to 87mm but I cannot find this kit in USA.
This kit is available in Australia from Bare CO. I understand that this is not too helpful to you in the U.S. but I thought I would mention that you also need to bore the block to take the larger liners ,at least for this Australian kit . This is not often made clear and the job becomes a lot more than a parts substitution and assembly task .
Your tractor might have came out of Canada, where 20-85"s were sold insted of/along side? TO-30"s. How about Fawcett"s in St Mary"s Ontario? Or if you are somewhere along the border, call an MF/AGCO dealer up ther. Bonchance.
I"m guessing our tractor came from Canada. I"m in Ohio so Canada isn"t all that far away. I didn"t know that this kit wasn"t a drop in so that may be a deal breaker. I was hoping that our only machine shop expense was going to be the crank and head. Thanks for the replys
What year is it? it may all ready be the 87 bore. My tea is a 52 there should be rised numbers behind the carb. whitch tells the year the motor was made but i don"t know how to find that info.
Ive found markings that say its a 51 but that is on the rear end housing, I think that may have been replaced at some time. The Hydraulic control fork inside has an aluminum bridge which wasn't supposed to be there until 53 and its 12v electronics with a lucas generator. Behind the carburetor the casting says 85, I dont recall a year on the engine casting.
OK i'm not sure but on mine behind generator reads 26 6 2 so i'm guessing the block was cast the 26th day on the 6th month on the year of 1952 and acording to the serial numbers it is a 52.
Only the early TEA's came with the smaller bore
