Gauges for early TO 35
Alec
Does anyone have any information as to the correct gauges for an early TO 35? A picture would be a lot of help.
Alek, I was at a meeting on March 9 and the FENA technical advisor Bob was there and he brought a reproduction of the temperature gauge and mentioned all of the gauges are in the process of getting remade. At this time the temperature gauge is available and the rest will be available in a short time. With that said you said, early TO 35. I do not know if they all used the same gauges or if there are different styles for different years. You could look at Steiners gauges as they are the ones having them reproduced.
Alex,
do your homework on the oil pressure gauge,
some of the old gauges did not read in #psi
they only read as green/red or high low.
with these gauges you really did not know what your oil pressure was.
I had an old AC D14 and its normal oil pressure was around 12-15 psi,
so if you installed a 60 psi gauge on it, the oil pressure looked low all the time.
I was able to find a 20 psi gauge and the needle stayed in the center of the gauge.
you want your gauges to read in the center of the dial at normal operation.
