Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Main bearings?
[Show Entire Topic]  [Return to Forum]
Dick New York
03-17-2013 20:23:32
67.255.63.34
First , check the guage , or replace it with a new one . Being that the pressure drops when hot , it is probably not the guage , but that is a good place to start .
Second , pull the base , and check the pump . Sounds like they are a weak point .
Third , plastiguage the mains that you can access , and the rod bearings .
?? Do you hear any knocks when it is hot . Have someone explain to you the different conditions , and sounds of rod , and main bearing knocks . They sound different , and happen under different operating conditions .
A bad main bearing can be annoying for a long time , but running with a bad main can cause damage over a period of time .
A rod bearing is more serious . It will only knock for a short time . The bearing will eventually spin , and sieze on the crank , and when it goes , it is a disaster . Chances are good that if a rod goes , it will ventilate the side of the block because it will break the rod when the bearing siezes .
Good luck
[Reply]   [No Email]
aarolar
03-18-2013 02:45:31
70.193.65.103
 Re: Main bearings? in reply to Dick New York, 03-17-2013 20:23:32
No I'm not getting any knocking at all how would you test the gauge? Is using compressed air accurate enough?
[Reply]  [No Email]
Trac
03-18-2013 07:57:58
71.48.107.173
 Re: Main bearings? in reply to aarolar, 03-18-2013 02:45:31
What i have done to check the gauge: Turn down the
air presser i have two gauges on my airtank 1 reads
the presser in the tank the other reads whats coming
out of tank if you can turn down the air that's
coming out your good to go so start off at
15bls.read the gauge see how close it is.
[Reply]  [No Email]
aarolar
03-18-2013 08:16:08
70.193.64.253
 Re: Main bearings? in reply to Trac, 03-18-2013 07:57:58
same way mines is setup that's what I was planning on doing
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
