Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Main bearings?
[Return to Forum]
aarolar
03-17-2013 11:11:22
70.193.65.103
So now I've got the hydraulics straight and all the other little nit picky things cleaned up on my TO-35/Z134 I need to address my oil pressure issues. After running my 5 foot tiller for about 45mins to an hour the pressure drops to 20psi at 1/2 throttle and at idle it reads 0 on my new gauge. When cold it reads 25 at 1/2 and 20 at idle, what's confusing is the motor runs extremely well and has 150lbs compression so its like someone resleeved and ringed it but didn't do any bottom end work.
Now my question is how feasible is it to go into the motor and only replace the main bearings and rebuild the oil pump. Being I just spent about 800$ on a new top cover and other hydraulic parts a full engine rebuild just isn't in the picture right now but I really need this thing mowing in a few months. Any thoughts are appreciated both good and bad.
[Reply]   [No Email]
Dick New York
03-17-2013 20:23:32
67.255.63.34
 Re: Main bearings? in reply to aarolar, 03-17-2013 11:11:22
First , check the guage , or replace it with a new one . Being that the pressure drops when hot , it is probably not the guage , but that is a good place to start .
Second , pull the base , and check the pump . Sounds like they are a weak point .
Third , plastiguage the mains that you can access , and the rod bearings .
?? Do you hear any knocks when it is hot . Have someone explain to you the different conditions , and sounds of rod , and main bearing knocks . They sound different , and happen under different operating conditions .
A bad main bearing can be annoying for a long time , but running with a bad main can cause damage over a period of time .
A rod bearing is more serious . It will only knock for a short time . The bearing will eventually spin , and sieze on the crank , and when it goes , it is a disaster . Chances are good that if a rod goes , it will ventilate the side of the block because it will break the rod when the bearing siezes .
Good luck
[Reply]  [No Email]
aarolar
03-18-2013 02:45:31
70.193.65.103
 Re: Main bearings? in reply to Dick New York, 03-17-2013 20:23:32
No I'm not getting any knocking at all how would you test the gauge? Is using compressed air accurate enough?
[Reply]  [No Email]
Trac
03-18-2013 07:57:58
71.48.107.173
 Re: Main bearings? in reply to aarolar, 03-18-2013 02:45:31
What i have done to check the gauge: Turn down the
air presser i have two gauges on my airtank 1 reads
the presser in the tank the other reads whats coming
out of tank if you can turn down the air that's
coming out your good to go so start off at
15bls.read the gauge see how close it is.
[Reply]  [No Email]
aarolar
03-18-2013 08:16:08
70.193.64.253
 Re: Main bearings? in reply to Trac, 03-18-2013 07:57:58
same way mines is setup that's what I was planning on doing
[Reply]  [No Email]
IrvIa
03-17-2013 17:55:11
207.199.229.145
All the suggestions are correct, but I'd take a hard look at the oil pump. They're noted for it. Mine was bad but ran good.
[Reply]  [No Email]
2tractors
03-17-2013 16:59:09
192.222.24.245
First and formost, where is the gauge from, sub it out, 2nd and formost is the screen clogged, 3rd. where is the gauge from, but last its a z134 so we ALL have experience. Once those 3 things are eliminated, re-- check all.Then, depending on how many times you want to drop the pan its once for each, pan gaskets leak-- twice to 3 times, rod plasti guage once, mains once,So you could have bad mains, rod bearings,guage, and even if the temp guage mal functions, the compressions figures being measured while cold are still impressive but only muddy the waters.I'm guessing the gauge has some green on the display and is NEW!
[Reply]  [No Email]
aarolar
03-17-2013 17:23:54
68.170.247.196
 Re: Main bearings? in reply to 2tractors, 03-17-2013 16:59:09
2tractors said: (quoted from post at 16:59:09 03/17/13) First and formost, where is the gauge from, sub it out, 2nd and formost is the screen clogged, 3rd. where is the gauge from, but last its a z134 so we ALL have experience. Once those 3 things are eliminated, re-- check all.Then, depending on how many times you want to drop the pan its once for each, pan gaskets leak-- twice to 3 times, rod plasti guage once, mains once,So you could have bad mains, rod bearings,guage, and even if the temp guage mal functions, the compressions figures being measured while cold are still impressive but only muddy the waters.I'm guessing the gauge has some green on the display and is NEW!
I don't get what you are asking about where the gauge is from but it is from orellys, I plan on dropping the pan and checking the screen, relief valve and doing some plastigauging whenever I get around to it and get the stuff together.
Tony in Mass,
Are you saying to just leave it alone and run it as is? I considered it but I am kinda spooky about it.
This post was edited by aarolar at 17:27:07 03/17/13.
[Reply]  [No Email]
2tractors
03-18-2013 18:46:50
192.222.24.245
 Re: Main bearings? in reply to aarolar, 03-17-2013 17:23:54
Is the gauge from any of the 3rd world countries, if so its useless, had one reading 5 lbs. after warm up and put a stewart warner guage in and got 30 lbs cold and 25 hot.
[Reply]  [No Email]
aarolar
03-18-2013 18:59:15
70.193.64.253
 Re: Main bearings? in reply to 2tractors, 03-18-2013 18:46:50
I'm sure its from the PRC, got some suggestions or links to a good gauge?
I just had another thought, could the oil filter cause a oil pressure drop? I ordered a spin on oil filter kit and it came with a fram filter that I couldn't get to quit leaking so I ran to town and got a Napa Gold. I noticed the fram had about eight or ten 5/16 holes in it for the return and the Napa Gold only had two 1/4 or smaller holes. I didn't run the fram long but I swear I had over 25 closer to 30lbs of oil pressure cold but with the Napa it won't go over 25 cold am I crazy or could this filter be that restricted?
This post was edited by aarolar at 02:59:08 03/19/13.
[Reply]  [No Email]
Tony in Mass.
03-17-2013 16:41:45
76.127.225.182
Confusious say, one should not open a can of worms unless he likes worms....
[Reply]  [No Email]
matt p
03-17-2013 13:57:31
69.31.197.148
just a few questions? what type of oil ,did you test your oil pressure gauge with air pressure to check its accuracy any oil leaks!!
I had a leak right below the gauge at the 90 degree fitting.
[Reply]  [No Email]
aarolar
03-17-2013 14:59:57
70.193.65.103
 Re: Main bearings? in reply to matt p, 03-17-2013 13:57:31
No oil leaks that's one of my pet peeves, I am running 15w40 with a quart of Lucas and no I have not checked the gauge with air.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
