I have a '52 TO 30 that does not like to start in the cold. I have to jump start it in the cold if i want it start. After it runs for a few minutes it will start easily after that. I thought the battery was the problem so i bought a new battery with 700 cca and it still wont start.
I push the clutch in while attempting to start and the timing was adjusted with a timing light per john uk's instructions. I checked the spark at the plugs and it is bright white like it should be and the gas is flowing fine. Once started it runs fine.
Any suggestions?
Any suggestions?
