Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Lift cover installation
Inno
03-13-2013 18:14:03
I think you just have to be brave and trust that it will do it's job. I went through the same thing on my 202, the dreadful pop the first time was the hyd. cylinder cracking under excess pressure from a fresh pump rebuild........if you replaced the relief valve you should be ok. According to John(UK) you should "blow off" the valve every so often just to make sure it's cleaned out and operating properly and to prevent another failure like the one you just fixed. With a properly working relief valve you should be able to raise your draft control lever all the way up then gradually raise your lift lever until it opens up.
