to30 3pt won't go down
Anonymous-0
The 3pt goes up an won't go down while tractor is running even with weight on arms no matter where u position levers u can bleed pressure offan they go down. As soon as you start it they go up an stay up any ideas????
Most likely, the control valve is stuck in the raise position. Access he valve through the side plate and with the engine off, pull backward on the "T" shapped valve stem attached to the bottom of the "H" shaped control fork. Excersise the control vale back and forth (~1 inch) and see if it moves easily in the control bore an make sure the "T" shaped bvalve stem is in the sockets on the control fork.
Ill try that when move lever doesn't feel like its moving anything. If shut tractor down an cracj plug open it goes down then when u start it all way up ill check the fork.
