Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: to30 3pt won't go down
Jerry/MT
03-12-2013 08:31:22
Most likely, the control valve is stuck in the raise position. Access he valve through the side plate and with the engine off, pull backward on the "T" shapped valve stem attached to the bottom of the "H" shaped control fork. Excersise the control vale back and forth (~1 inch) and see if it moves easily in the control bore an make sure the "T" shaped bvalve stem is in the sockets on the control fork.
m.Watson
03-12-2013 18:53:07
 Re: to30 3pt won't go down in reply to Jerry/MT, 03-12-2013 08:31:22
Ill try that when move lever doesn't feel like its moving anything. If shut tractor down an cracj plug open it goes down then when u start it all way up ill check the fork.
Charles in Aus.
03-13-2013 01:04:07
 Re: to30 3pt won't go down in reply to m.Watson, 03-12-2013 18:53:07
Be sure the engine is NOT running when you do this !
