Ferguson Belt Convertor
I was given a part for my Ferguson To35 Tractor that bolts on the PTO Shaft on the back of the tractor that allows me to use the older style belt driven equipment. Does anyone know what this is called and when they were made? Many thanks to all.
There was a part called the PTO Adaptor which bolted to the rear PTO shaft using the anchor bolts and converted the standard 1-1/8" splined PTO shaft to the ASE 1-3/8" splined shaft for use with the newer implements that used the larger shaft. It had a shield too for safety. I don't know the Ferguson part number but Dearborn offered one too.
Sorry -misread your post but the part is called the Belt Pulley. Originally a Ford 9N accessory,it had a 9" Rockwood pulley and was used to drive threshers, cordwood saws, grist mills, etc.
