putting things to goode use
s19438
after three hours of cutting, dragging and stacking i need a nap.
The box is not homemade. It's a sauder's coffin style box Made by the sauder co. New holland Pa.
Sometimes when found at auctions and farm sales they were missing the bracket and pin that connects under the seat because it went with the tractor and wasn't taken off.
Kirk
i thought the carry-all started life as a ferguson and some one added the front sides. it seems to have a home made bracket for connecting to the top link.
thanks for the info.
Original bracket bolted under the seat spring and was flat steel with a pipe style loop at the end were the pin went. Because of the reason I stated Homemade brackets were not uncommom.
Kirk
BTW I just seen your reply about the TO35 grille.
Yes it did have a grill but had a loader on it so the bottom was cut up. Kirk
It was there the day I was there. Today, who knows. I pulled an engine of a ford 2n that day.
It's a UPullit yard so parts go pretty fast. I took the starter, which I just sold on ebay, and the carb, and an umbrella holder off the rear. otherwise the tractor was pretty much complete with front loader. If your close, in eastern Pa, and need some parts might be worth a look see.
Kirk
EZpull New Ringgold PA.
If you do go, walk thru the gate and there will be a fence encloser in front of you, make a right and walk half way around it, can't miss it. While there if you see any fords other than the 2n I pull the engine off please let me know. They don't aloud cameras but a phone picture would be nice.
Click on my email and let me know how you did.
Kirk
