i have a 1957 To-35 ferguson tractor,
It has GL-1 oil in the trans/hyd system, has been a few years since it was changed.
I wanted to check and be sure there is no water in the oil.
Question: if there is any water in the system, how long should the tractor set for the water to seperate and collect at the bottom of the drain?
I want to crack the drain plugs and see if there is any water in the system.
But if the water is mixed with the oil, then i would not get a proper sample.
thanks for your replys,
