TractorLinks.com
Show Parts for Model:
Re: trans/hyd oil question
Jason S.
03-04-2013 11:15:06
If it hasnt been changed in a few years then more than likely there is water in it. If nothing else it will be in there from condensation. When you check it on the dip stick what color is it?
maxwell99
03-04-2013 19:45:22
 Re: trans/hyd oil question in reply to Jason S., 03-04-2013 11:15:06
On the dipstick the oil is clean, no sign of milky discolored oil.
the tractor always is stored inside and the shifter boots are in good condition.
moisture would come from the housing sweating, but I was just concerned that moisture could buildup over a long period of time.
this is the only time of the year that I am not using it at least ever few days, so I thought it might be a good time to drainout a bit an check for water.
Might drain and change the trans/hyd fluid this year as it has been at least 5 years since it was changed.
phil(va)
03-05-2013 12:05:36
 Re: trans/hyd oil question in reply to maxwell99, 03-04-2013 19:45:22
Unlike engine oil, if isn't milky, it won't go bad. As I said, it's expensive to replace, and not friendly to the environment either.
