Proper fuse plaecment
aarolar
I just got done rewiring my '55 TO-35 to correct a bunch of issues and am curious where I should go back and place fusees? The only fuse I see on the wiring diagram is for the lights do I not need one somewhere in the ignition circuit?
If you really want to add one in to the circuit I wouldn't use a fuse. I would use a fusible link, lots of cars and trucks used those back in the day on the ignition circuit. Older Fords fusible links were in the wire it's self and you can still get those in different amperage ratings. If I was going to add one in to the circuit that is what I would use because they work well and aren't detectable like a fuse and holder is, if you were concerned about looking original.
