Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Busted hydraulic top cover
samn40
02-28-2013 18:31:46
As long as the studs are the correct diameter then the covers are interchangable. But if you go for a later cover the casting is heavier so you need the longer studs and the longer stack pipe. With the cover on the tractor, lift the link arms by hand until they are fully raised, now scribe a line across the top arm and the cover. Scribe another line on the cover about 1/4 inch from the first one. Now with the tractor running raaise the position lever very slowly until the second scribe mark lines up with the mark on the upper linkarm. Put a bolt and nut with a flat washer either side of the lift quadrant and tighten it so the lever can only raise to this height. That should keep the new cover safe!......Sam
Copyright © 1997-2015 Yesterday's Tractor Co.
