TractorLinks.com
Show Parts for Model:
Re: Something unusual happened today...
Tony in Mass.
02-17-2013 13:16:16
Lucky you... or was it the 35 below windchill?? And which tractor is this? and interesting point in a project, please tell us more... unless it involves a Standard 23 C....
Dan S (NY)
02-17-2013 13:43:15
 Re: Something unusual happened today... in reply to Tony in Mass., 02-17-2013 13:16:16
This is the 35 I got the summer of 2011 with a broken oil pump. So far I have put in a oil pump rebuild kit, had the cranked turned and put in new bearings. The head has been in for new valves/guides and the power steering box needed a new rack. About three weeks ago I finally test started it and it ran really nice with oil pressure at a steady 35 psi. Power steering seemed to work nicely as well. I had filled the cooling system with hot water prior to starting it so after running it for about 20 minutes it was pretty warmed up. Now I need to re torque the head and start assembling the dash and wiring. The hydraulics did work but it needs some adjustments so I am pulling the top cover to do that plus clean things out. This has tuned into a long term project but I think it will be a nice worker when done.
Dan
2tractors
02-17-2013 16:45:13
 Re: Something unusual happened today... in reply to Dan S (NY), 02-17-2013 13:43:15
After rebuild wth great oil pressure and your doing the lift plus the power steering is now in good shape,gees I guess the clutch or something must be bad.U got all the luck!!
