Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: oil pump for a to-20
Tony in Mass.
02-15-2013 16:40:39
Well, I have one I just rebuilt that fits Z129 and 134's, if it fits yours I'll send it...but... you got a fork in the road here. Your engine is getting tired, you either need to to just maintain what's there, and go easy and carefull with it, or... especially 'OR'- if you intend to drop the pan and tear into the front main to do this oil pump... for another few days and few hundred bucks, which is the hard part I know... you could have the whole engine on the floor and put in a whole rebuild kit. Or alteast do the bearings and rings? I have a hunch your rear main is scored, and as the metals and oil heats up, the pressure drops. OR... get some grey paint and smear in on your gauges....
purecty
02-16-2013 02:23:23
 Re: oil pump for a to-20 in reply to Tony in Mass., 02-15-2013 16:40:39
i unhooked the oil line and oil came out, not fast but it was a steady stream. maybe i better just leave it alone, as i dont have few hundred to spend. thank you kindly. i would like to have an oil pump though in case i do get to it bill
purecty
02-16-2013 03:02:25
 Re: oil pump for a to-20 in reply to purecty, 02-16-2013 02:23:23
i unhooked it from the gauge and started it. it came out ok, not a surge or anything like that, just a slow stream
purecty
02-16-2013 03:32:50
 Re: oil pump for a to-20 in reply to purecty, 02-16-2013 03:02:25
it has 30 wt. oil in it. should i change it?
purecty
02-16-2013 02:37:13
plus the tractor doesnt any power
purecty
02-16-2013 10:05:50
 Re: oil pump for a to-20 in reply to purecty, 02-16-2013 02:37:13
im sorry the tractor does not lose power
Jason S.
02-16-2013 05:57:29
If the tractor doesn't have any power it may need the governor adjusted. I've learned the hard way that it doesn't take much to throw them out of adjustment and it won't have any power.I run 30 weight in my TO20 myself.I won't say for tractor engines but I know on car engines 10 psi of oil pressure per 1000 rpm's is ok. I would think as long as you have 10-15 pounds you should be fine. Also a lot of the gauges you get now arent the most accurate when it comes to tractors. I have heard of new gauges being off up to 10 psi before. Sorry to hear about your health problems.
purecty
02-16-2013 10:07:23
 Re: oil pump for a to-20 in reply to Jason S., 02-16-2013 05:57:29
jason, the tractor doesnt lose any power thai can tell thank you kindly bill
purecty
02-16-2013 06:54:40
thank you kindly
purecty
02-16-2013 03:52:52
i dont want to really get into something if its not necessary. i am not able to do it or the money for it. i am lucky though, i can find someone to help me free of charge so that really helps a lot/ this is my first tracor and i am proud of it. it dont leak oil all over the place and it has never used a drop of oil. it makes no noise that i can tell i know nothing about tractors but im learning a little bit as i go along. and again i thank all you guys on here. johnuk has been wonderful and richard has been great and he even gave me a part for my to-20. no charge. i havent gotten over that yet and i am very grateful to him also. i am an old man and getting older, but i still know how to say thank you bill
2tractors
02-16-2013 05:49:59
 Re: oil pump for a to-20 in reply to purecty, 02-16-2013 03:52:52
Sorry to hear about your health problems,hope everything works out well for you. Seems like all of us up in years will have to deal with cancer at some point. You will need to acquire a torque wrench to replace the pump.
purecty
02-16-2013 06:56:07
 Re: oil pump for a to-20 in reply to 2tractors, 02-16-2013 05:49:59
thank you very much.
Copyright © 1997-2015 Yesterday's Tractor Co.
