Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: oil pressure- to-20
Dick New York
02-11-2013 20:46:29
Like stated . First , check the guage . The one you have may be bad . Check to see if you have had a lot of Gasoline drain into the pan . The rod and main bearings can be checked with what they call " Plasti-guage " . It can be picked up at a auto supply store . You remove the pan . Then , one at a time , you pull the rod / main bearing cap off . You visually check to see if the bearing is in good shape . Now you put a piece of this plasti-guage on the journal , and replace the cap . You torque it down to spec.. Now you remove the cap , and measure the width of the plasti-guage . The amoune that it squishes out to indicates what your clearence is . If you find that the bearings are worn , and the crankshaft journals look good , then you can get new bearings . If you are going to replace bearings , you would measure the crank journal to determine if it is standard size , or under sized . You would buy replacement bearings accordingly . They come in sizes ranging from standard , to several thousands undersize , etc. , etc. . Check your oil pump . good luck
