Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: oil pressure- to-20
Jerry/MT
02-11-2013 16:45:35
Your oil pressure relief valve either has too strong a spring or the valve is stuck shut. Normal oil pressure is 25-30 psi and min is 15 psi with the engine at operating temperature idling at 400 rpm. The drop you see are the clearnace opening up due to temperature, with no pressure relief from the oil pressure relief valve.
Check the relief valve or you are likely to to start the rear main leaking into the bell housing.
purecty
02-12-2013 02:59:59
 Re: oil pressure- to-20 in reply to Jerry/MT, 02-11-2013 16:45:35
where is the relief valve?
Jerry/MT
02-12-2013 07:07:00
 Re: oil pressure- to-20 in reply to purecty, 02-12-2013 02:59:59
It"s a part of the pump.It"s a little piston and a spring held in place by a cotter key and maybe shimmed with some washers.
purecty
02-12-2013 09:42:33
 Re: oil pressure- to-20 in reply to Jerry/MT, 02-12-2013 07:07:00
thanks a bunch. im gonna put another gauge on it today i think. i done busted a rib messing with that thing or something. under my right arm hurts leck all get out/ dont know if i can do it or not. but i'll try. bill
Copyright © 1997-2015 Yesterday's Tractor Co.
