| Harry Ferguson Tractors Discussion Forum |
Topic: Re: TO20 radius arms
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| John(UK)
02-05-2013 02:41:21
79.76.247.146
  The reason the Radius Rods have bent is that the Centre Axle Pin and Bush is worn and is allowing the axle Beam to twist, allowing the wheels to move back-wards under the tractor. There should be no twisting load on the Radius Rods at all, it should all be taken by the Centre Pin. The Radius Rods are really only there to give support to the outer ends of the axle when the wheel Track is opened wider. If you don"t replace the Pivot Pin, the wear will allow the Axle Beam to rise more than it should when the tractor is running on rough ground or if the left side wheel lifts for any reason, this will allow the Axle Beam to strike the bottom hose connection on the Radiator and in some instances will knock it off completely. There are more than one bush and pin combination for these tractors, so make sure that you get it right. Early tractors had a thin wall bush, later tractors had a thick wall bush with a collar on one end. This later Bush has a larger outside diameter and will not fit in place of the thin wall bush, it needs a different axle beam to do that. The 35 tractors are like this and the beam will interchange. You should fit 2 of the heavier bush although it was only listing one in the parts list, this gives better support. When the axle bushes and pins are correct, it restores the Castor angle of the King Pins and you will find the steering very much lighter. A good indication that there is wear in the Axle Pin is that the steering will "shimmy" when you try to run at speed on the road.If you want more info about the Pins and Bush combinations, email me giving the length of the Pin.. You should also check the Thrust Bearing at the bottom of the King Pin (see pic attached)as it doesn"t get too much lube if it is worn, the grease comes out of the top instead so you stop pumping the grease, this too will make the steering much lighter. John(UK) fergusontractors@hotmail.com |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
