Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO 35 Housing
samn40
01-29-2013 13:55:34
Have both tractors 6 bolt axles? out at the brake drum I mean. You will have to check parts numbers...but yes the 40 axle should fit, but it may need reshimmed. Sam
miner09
01-29-2013 14:36:10
 Re: TO 35 Housing in reply to samn40, 01-29-2013 13:55:34
Both(1956) are 6 bolts. Housing casting #'s are the same. Will I have to reshim axle even if I don't take apart at brake drum?
Dan S (NY)
01-29-2013 19:22:30
 Re: TO 35 Housing in reply to miner09, 01-29-2013 14:36:10
You will need check the axle clearance because it is adjusted by the shims in both axles working together. You will be taking the axle from one side of one tractor and putting it in another so there is no telling what kind of axle clearance you will end up with.
Dan
Copyright © 1997-2015 Yesterday's Tractor Co.
