TractorLinks.com
Show Parts for Model:
Re: TO 35 Housing
Dan S (NY)
01-29-2013 12:04:18
You have to tighten the lower lift arm pin from the inside. If you remove the left hand axle housing and then slide out the ring gear assembly you can get to the nut on both lower lift pins. If the tapered hole in the axle isn't wallowed out you should just be able to tighten it up. In the picture, the pin has been removed from the right side so you only see the hole it goes in.
Dan
miner09
01-29-2013 12:17:55
 Re: TO 35 Housing in reply to Dan S (NY), 01-29-2013 12:04:18
The pin is not in axle housing? I think he pin is wallowed out from what I can tell, real loose. Thats why I want to just replace complete housing from parts tractor.
