TractorLinks.com
Show Parts for Model:
Re: TO 20 axle clearance
Jason S.
01-27-2013 18:53:12
It will cause more damage than just oil seals leaking...I done some looking and here are John(UK) words on it....
You can get the shims from a Sparex dealer as part S42622 these are .010" The MF part number is 181-232M1, you can also get some from later models that will fit. 35/135"s and any tractor types with same drum brakes, these shims will fit but they will have 12 holes instead of the 6 holes for the grey tractors. Do Not use paper gaskets as a substitute and do not use any sealant or the Hub will move on the axle and it will leak again. Paper gaskets should be fitted one each side of the brake back plate and the shims go next to the Rear axle housing. It is important that there are sufficient shims or the bearings will be overloaded when you tighten the Hubs to the tractor.Too many and it will knock as the bearings will be too loose and in severe cases it could knock the collars off the shaft..John
fergusontractors@tiscali.co.uk
