| Harry Ferguson Tractors Discussion Forum |
Topic: TO 20 axle clearance
[Return to Forum]
| Author |
[Modern View]
| 37Chief
01-27-2013 17:07:01
68.8.206.100
First thanks for all the information you folks have given me on my TO 20. I think this will be the last thing I need. What is the distance between the axle ends? I have .003 on one side, and .002 on the other. Don't know why the are different, but they are. Think if I assemble it dry it will not leak/ Thanks Stan |
| Bruce(OR)
01-27-2013 18:03:04
97.115.30.214
Re: TO 20 axle clearance in reply to 37Chief, 01-27-2013 17:07:01
| Not too sure I understand this. Clearnce between the axle ends. ? I must be dense. Are you talking about the amount the axle can be pulled away from the tractor when all bolted up? Well shoot! Got the book open already in front of me. Musta been tooo lazy to put it away. X 0.002 - 0.008 clearance between inner ends of the axle shafts. Zero clearnce may cause the inner ends of the axle shafts to weld together. Excessive clearance will result in damaged axle shaft oil seals. X Now if you have installed Sure Seals installed, then you will not have an issue with excessive clearance causing damage to the oil seals as the Sure seals are installed in the axle shaft retainer which is held in place by the axle shaft collar which has set your bearing preload. Time to put this book away. Gotta find me a round-tuit... One of these days I will finish the wife"s TO-20. |
| 37Chief
01-27-2013 21:33:20
68.8.206.100
Re: TO 20 axle clearance in reply to Bruce(OR), 01-27-2013 18:03:04
| Thanks Bruce. That is the number I wanted. .002 to .008 This is what I am refering to as the distance the axle ends can keep from touching each other. I measured it with my dial indictor, so I am within specs. My axle's had no clearance, the axle ends were shinny, indicating to me they were really bumping each other. I added .010 to get it within specs. Stan |
| Jason S.
01-27-2013 18:53:12
174.252.177.141
| | It will cause more damage than just oil seals leaking...I done some looking and here are John(UK) words on it.... You can get the shims from a Sparex dealer as part S42622 these are .010" The MF part number is 181-232M1, you can also get some from later models that will fit. 35/135"s and any tractor types with same drum brakes, these shims will fit but they will have 12 holes instead of the 6 holes for the grey tractors. Do Not use paper gaskets as a substitute and do not use any sealant or the Hub will move on the axle and it will leak again. Paper gaskets should be fitted one each side of the brake back plate and the shims go next to the Rear axle housing. It is important that there are sufficient shims or the bearings will be overloaded when you tighten the Hubs to the tractor.Too many and it will knock as the bearings will be too loose and in severe cases it could knock the collars off the shaft..John fergusontractors@tiscali.co.uk
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
