shimming rear axles...
Bruce(OR)
So, when I raise the rear tires off the ground with properly shimmed the rear axles and spin one wheel forward, the other wheel should turn in the opposite direction. Correct?
That is with correctly shimmed axles.
Now if the shims are missing or not enough installed, the tires will both turn in the same direction. Correct again?
Yes, but if the clearance is too wide they would still turn in opposite directions. If you don't have a dial indicator I would remove shims until they do make contact and then shim it until they turn opposite of each other, and use the paper gaskets instead of silicone when you are checking it and putting it together.
The axle bearings will get damaged, because the cup will not stay tight in the cone so it will hammer the axle bearing out eventually plus with the axle moving in and out it will act like a pump and you will have grease running down onto your brake shoes.
I just read the book. Im actually had it pulled out for the cam nut torque question and flipped it to the rear axle page.
yada, yada, blah, blah, blah...
"Excessive clearance will result in damaged axle shaft oil seals..."
It appears the outer bearing are retined by an axle shaft collar and therein is the bearing preload with floating axles that slide into the final drive.
If Sure Seals have been installed then excessive clearance should be a moot issue.
(quoted from post at 23:06:46 01/26/13) I just read the book. Im actually had it pulled out for the cam nut torque question and flipped it to the rear axle page.
If Sure Seals have been installed then excessive clearance should be a moot issue." No, you still have bearing life to be concerned with. Bearings are not happy running with a bunch of slop.
Granted. The axle is a floating style and the bearings are held in place with the retainer collar. Consequently, the shims give the proper clearance to keep the axles from rubbing and maintain axle seal integrity. If installing Sure Seals, axle seal integrity becomes a moot issue.
Then the only issue remaining is to prevent axle ends from contacting inside the carrier.
Looking at the diagram the outer shaft retainer holds the bearing and is held in place with the collar. That collar being an interferance shrink fit.
I believe you can find this on page 25 of the I&T shop manual. Figure F43 items 18,25,21 and 20.
Paragraph 94 makes mention of the oil seal.
To lazy to pull the book back out.
Please explain to me how that would work.
The retainer collar is heated up and slides into place down the length of the axle shaft.
It shrinks into place and is retained by an interferance fit.
Now the entire axle shaft is a "floating style" axle meaning it has no retainer clips inside the differential to hold the axles in place.
So, what holds the bearings in place?
the axle shaft retainer?
Feel free to consult your I&T shop service manual.
Figure F43
Part 24 is effected by part "A". How does part "A" effect part 21?
Part "A" will have an effect on 25 and 18 contact area when not running Sure Seals.
The installation of Sure Seals negates the fitting problem of 25 and 18.
Also note worthy are the long splines on the end of 18.
