Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO-35 steering column
buckingbrutus
01-22-2013 15:25:49
Took the steering column apart some today...steering shaft looks good and tight, although the lower bearing is shot. Also found 10 extra rollers down there, possibly from a shot upper bearing?? Yall say the manual steering can fail, Are the bearings typically the culprit? there is a little chip in one of the teeth on the pitman-arm shaft (see second pic), although it doesn't look like a problem and it's just on the one tooth; the pitman shafts appear good and tight. Just wanna make sure I get all the parts I need
Also found a piece i don't recognize; its in the picture, the thin washer piece with a rivot. Just wondering where that may have come from
In some more searching around for interchangeability, it appear's the TO-35 is the only model that will have the steering column I need; the TO-30's and MF 40/50's both look different.
