TractorLinks.com
Show Parts for Model:
Re: Connecting Rod Orientation
matt p
01-22-2013 12:48:00
Just looked at the manual it says to have #'s toward camshaft and the oil spray hole which is higher up on the rod toward the thrust side of engine opposite the camshaft. Did you reverse the rod caps when you had them off for inspection. check closely their should be a # on the rod as well. If you need to change you will have to pull the head.Check your oil spray hole. this is from the z134 engine manual yours might be a z129
