TractorLinks.com
Show Parts for Model:
Re: 134 piston direction?
Dick New York
01-20-2013 20:07:20
I haven't had one of these apart . Looks like you have them installed in two different directions . It may not mean anything , as far as the piston is concerned , but , I would check the rods on the crank end . I would imagine that the crank end of the rod would have a mark , probably the hole number , #1 , #2 , #3 , #4 . You should make sure that the rod caps are bolted to the rod correctly . I would imagine that they should all be in the same direction . I would check a rebuild manual to make sure that the rods are installed correct . It can be a expensive mistake if they aren't . Good luck .
