Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: atf or hydraulic fluid?
01-20-2013 15:10:26
Does you loader have a front mounted pump with a reservoir or does it use the pump in the transmission?
If it is the pump in the transmission do not use either oils. The transmission is not designed to use either of them.
If it is an external mounted pump running off the crankshaft, I would use hydraulic oil.
rusty nut
01-20-2013 15:33:17
 Re: atf or hydraulic fluid? in reply to VTParts, 01-20-2013 15:10:26
thanks for quick answer it has the pump on the front,thanks for your answer.
01-20-2013 15:52:55
 Re: atf or hydraulic fluid? in reply to rusty nut, 01-20-2013 15:33:17
No problem, good luck with it.
