Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: oil pressure
purecty
01-20-2013 08:44:14
i had checked the pressure on all 4 cylinders a few months ago and they were all about the same
purecty
01-20-2013 09:05:04
 Re: oil pressure in reply to purecty, 01-20-2013 08:44:14
how do you get the gauge out? un-screw the 2 bolts[ one on each side] and unhook the oil line and push it out the front? sorry fellows, but im no mechanic. lol thanks
Richard L
01-20-2013 11:47:11
 Re: oil pressure in reply to purecty, 01-20-2013 09:05:04
You sound as you are correct remove oil line nut. Then the two nuts on the back of the gauge, pull off the U shaped holder under the nuts you just removed then push the oil gauge backward out of the dash. You can remove the oil line from the gauge in the dash and attach it to the new gauge and hold it to see if it will work w/o actually installing the new gauge. It is up to you.
purecty
01-20-2013 13:05:29
 Re: oil pressure in reply to Richard L, 01-20-2013 11:47:11
thanks a lot richard. that is what i wanted to know. how have you been doing? ok i hope bill
purecty
01-20-2013 09:14:03
where is the oil pump?
Richard L
01-20-2013 11:37:05
 Re: oil pressure in reply to purecty, 01-20-2013 09:14:03
The oil pump is on the bottom of the block in the oil pan area.
purecty
01-20-2013 10:45:43
what if i take the oil line loose from the gauge? can i start it with the line loose to see if oil is coming out without any problems? thanks bill
Richard L
01-20-2013 11:35:22
 Re: oil pressure in reply to purecty, 01-20-2013 10:45:43
You can take the oil line off and start it, however if the oil line is not plugged and everything is working correctly oil should come gushing out.
purecty
01-20-2013 13:08:06
 Re: oil pressure in reply to Richard L, 01-20-2013 11:35:22
i just wanted to see if oil was coming out. if it is then i guess it would say its a bad gauge bill
