Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Lost oil press???
Dick New York
01-18-2013 17:22:16
Sounds like it has been overheating . 1 - Could be a bad oilpressure guage . Disconnect line , and check the pressure . 2 - Could be bad rod , or main bearings . Is it making a knocking noise . I have a to30 that has a bad guage . To torment me for awhile , it has a bad wristpin . That can sound like a bad bearing . 3 - Could have a bad oil pump , or a plugged oil pick up or filter . You might pull the pan , and check the pickup . This will only cost you a gasket . Do you have oil pressure when cold , and it goes away when hot . If so , DON'T run it . That is a bearing , or pump problem . That can get real serious , real quick . Hope this helps Good luck .
I hope that it is the guage
