Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Non draft control top link pin
[Show Entire Topic]  [Return to Forum]
John(UK)
01-09-2013 11:19:40
79.76.250.201
I have seen them broken off before and it has always been due to some clown towing from just one lug on the casting. They don't break easily but when they snatch at it and possibly not pulling in-line as well, anything can happen. I have also had one break when trying to remove the bush out of the center of the Top Link Rocker, they didn't warm it up and it was seized solid, so you can guess what would happen. You simply use the Top Link connection for most implements, if was meant to be attached on the hinged pin it would be a totally different fitting. Always attach your implements to the Top Link connection unless it has a different fitting than a normal top link. If you have any doubts about a particular implement, just email me with a picture of it if you can and I will be able to tell you. But to clarify, it doesn't matter if you are using the Draft Control or not, you nearly always attach the Top Link to the Draft Control Spring. It is made to operate like this. I say NEARLY ALWAYS because there are a few exceptions to this rule, but these implements are now few and far between. Draw-bar stays on a TO20/30 and TE models always attach to the Top Link connection, the picture I sent last time was for a TO35 and they attach to the long pin as in the picture, you could use these on your tractor if the Pin was not broken.
John(UK)..fergusontractors@hotmail.com
[Reply]   [No Email]
Tom in MO
01-09-2013 12:42:21
64.136.27.163
 Re: Non draft control top link pin in reply to John(UK), 01-09-2013 11:19:40
Thanks, John.
Given that I can use attach (virtually) all implements to the Draft Control Spring, would it even be worth the trouble to try to repair the casting at the other (lower) attachment point? (Unless I completely run out of things to fix, that is!)
[Reply]  [No Email]
John(UK)
01-10-2013 01:37:00
79.76.250.201
 Re: Non draft control top link pin in reply to Tom in MO, 01-09-2013 12:42:21
No not worth it. If we had been having this conversation 50 years ago when the tractors were still in work full time it may have been different but these days very few attachments would use that connection point as I said yesterday. Unless you are a perfectionist and want to show the tractor, forget it. Most implements are made to use the Top Link Connection and not the long hinged pin. The top link attachment point is only working when the implement is in the ground, NOT when the implement is above the ground as there is no pressure from the implement to operate the draft control. This is how it is meant to operate so don't think about it anymore..John(UK)...fergusontractors@hotmail.com
[Reply]  [No Email]
Tom in MO
01-10-2013 04:58:14
64.136.27.164
 Re: Non draft control top link pin in reply to John(UK), 01-10-2013 01:37:00
Actually, John, I took a closer look, and the attachment point is fine.
What I was seeing was the original long, hinged pin (it looks original, anyway), that was broken off on one end. (It looks like it seized in the hole/bushing.)
I"ll just (carefully) extract that broken/seized pin, and I should be good to go.
Thanks again.
[Reply]  [No Email]
John(UK)
01-10-2013 07:43:57
79.76.240.57
 Re: Non draft control top link pin in reply to Tom in MO, 01-10-2013 04:58:14
Wonderful, glad that it is OK. The hinged pin on a TO20/30 or a TE tractor should have a shoulder on the Pin at the opposite end to the Linch in hole. This is to allow a bigger hole on the casting so that you an pull out the Bush through the bottom of the Top Link Rocker, the Hinged Pin on a TO35 or 65 does not have this shoulder, so be aware if you buy a new pin..John(UK)...fergusontractors@hotmail.com
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
