TractorLinks.com
Show Parts for Model:
Re: TO 35 Dual Stage Clutch Replacement Cost
danderson
01-07-2013 12:30:12
Joe, I have a set of Transmission seals, one for the main shaft and one for the PTO shaft. If your going that far you might as well replace them. You can have them for the cost of postage.
Joe Strohsack
01-07-2013 14:26:35
 Re: TO 35 Dual Stage Clutch Replacement Cost in reply to danderson, 01-07-2013 12:30:12
Well I found out a couple of things, First of all the owner (not me) plugged the weep hole in the bellhousing with a golf tee, there for getting oil on the clutch. I cleaned the disc best I could from the inspection hole with brake clean and adjusted the clutch as per the IT manual. The owner does not want to go the the expense of a seal change, so I am going to change out the trans oil because it is very milky (and THIN). I told him we will leave the oil level a tick low and not to park it in a down hill position and NEVER plug that hole again. Thanks for all the help from everyone.
