Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Wrong Carburetor for TO 35?
[Show Entire Topic]  [Return to Forum]
John(UK)
01-07-2013 07:18:57
79.76.249.75
You really need to locate the correct Carburettor for this Engine as Jerry has said. It can be either a Carter or a Schebler. Always use the correct gaskets on a Carburettor or it will suck air or leak fuel. Make sure that the height of the fuel in the Carb Bowl is correct at all times. This should be 13/64" (on a Schebler)from the top of the Float to the machined face of the Carburettor top casting, where it would attach to the bottom Bowl this setting must be accurate and because of this the correct thickness of gasket is necessary. To adjust this clearance you can use needle-nose pliers to alter the Float clearance. On a Schebler Carburettor, the clearance is 1/4" from the machined surface of the Top Casting BUT WITH THE GASKET IN PLACE to the nearest part of the Float. So in this instance you measure from the top of the gasket to the Float, which is different to the Carter Carb. When you are measuring this clearance on both types of Carb, you have the Top Casting upside down to how it would be mounted on the Engine, in this position the Float will drop and be in the shut-off position and then you can measure the clearance. In both instances make sure that the shut-off valve is in good order and that it isn't marked due to wear, change it if there is any doubt about it or it may leak and overfill the Carb. which in turn will cause the engine to run erratically, no matter how you try to adjust it.
John(UK)...fergusontractors@hotmail.com
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
