| Harry Ferguson Tractors Discussion Forum |
Topic: Re: Wrong Carburetor for TO 35?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Jerry/MT
01-06-2013 17:50:09
206.183.116.145
Ihe TSX 361 was designed for a 12O cu in displacement engine and your TO-35 has a 134 cu in Z134 IIRC. You need something to handle about 12% more airflow. The best thing to do is to find the correct carb for you tractor. You could probably use a TSX 458 from the Z129 powered TO-30 and adjust it adequately because there is only around 4% difference in air flow and the TXS 458 has the larger venturi. Having said all of this, if the tractor ran fine in the past with a TSX 361 I would suspect the poor running condition you are experiencing now is due to either a dirty carb or a poorly maintained ignition system. How have you concluded that the carb is the problem in the first place? Most poor running issues that are blamed on carbs turn out to be ignition related! So check you spark and see if you have the requisite FAT, BLUISH-WHITE SPARK, the color of lightning. Check the distributor shaft for wear and check the initial timing. You said your carb had a lot of rust in it. It"s likely unless you soak it in carb cleaner of over 24 hours and then blow out all the passages to make sure they are flowing freely, you still have some crud in your carb"s metering passages. You may have to manually clean some of these passages with small wire to get 50+ years of crap and corruption out of these passages. Make sure that you set the float correctly because the float setting on these carbs in important. Always shut the tank valve off when you shutdown to preclude fuel leaking from the carb. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
