Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Wrong Carburetor for TO 35?
Jason S.
01-06-2013 13:38:18
A TSX 361A is for a TO20, a TO30 used a TSX 458 and a 35 used a TSX 605 I think, or it could of had a Zenith carb on it also. Will it run with a 361? Yes but it may run lean. You should pull the spark plugs and see what color the tips are. If they are a white to grayish color. Your too lean. If you are gonna be doing some pretty hard work with the tractor I recomend getting another carb. If it is something you hardly ever use and just do yard work it will probably be ok. You can always richen the mixture up on it. I would also recommend that you rebuild it with a proper kit and anytime you park the tractor you should turn the fuel off.
01-06-2013 20:22:17
 Re: Wrong Carburetor for TO 35? in reply to Jason S., 01-06-2013 13:38:18
For the most part what you get in the kit will probably work on a hundred different ones.
