| Harry Ferguson Tractors Discussion Forum |
Topic: Re: Non draft control top link pin
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Inno
01-05-2013 22:06:49
64.229.157.71
Thanks for the pictures. Will it hurt anything to connect a mower as Bob has it there? I don't imagine there is a need for draft control on a mower but is it harmful to do it that way?
What sorts of things are the lower attachment points designed for?
Tony, did that tractor come from the wreck of the Titanic? Pretty rusty lookin'. My bucket of bolts probably doesn't have one that long. |
| miner09
01-06-2013 10:30:25
75.230.230.135
Re: Non draft control top link pin in reply to Inno, 01-05-2013 22:06:49
| John(UK)
01-06-2013 09:14:18
79.76.240.215
|  Nearly all Ferguson implements attach to the Top Link connection, only a few special implements use the lower hinged pin. A Post Hole Borer is one, the Trailer Hitch is another and draw-bar stays for the linkage draw-bar, but there are a lot more. It is just a stronger attachment point and was used on the old Grey tractors right from the very early days. You can safely use the Top Link connection to attach your Ferguson Mower without any problems as it is made to attach at this point. Regarding Draft Control, obviously you don't use it as it is not running in the ground, so you use Position Control if you have a 35 type tractor, which will hold the mower at whatever height you need to set it above the Ground and you move the Draft Lever down to the bottom of the Quadrant out of the way. If you have a 20 or 30 type tractor, then you use the Chain in the center of the mower draw-bar, hooked into the Rack on the Top Link to hold it at the correct height (PTO shaft Level) and lift and lower with the Quadrant Lever as normal....... John(UK)...fergusontractors@hotmail.com |
| maxwell99
01-06-2013 05:49:41
208.78.250.177
| Inno, I have a 1957, TO35, it came with the cross bar hitch just like the one in the picture. Later we bought a under belly rear hitch for the tractor. I also use the stabilizer arms that go from the end of the lift arms up to the long pin when i have my seed sower mounted, it runs off a rubber hose connected to the pto and the seeder must be at the same level all the time, so you do not ruin the drive line hose. somewhere down the road i have seen a bracket that fits onto that long bolt, the bracket has a connector like the normal top link connection. If you look up the old fergy post hole digger, the top link of the phd was attached to that long pin not the req top link. Harry Ferguson and his boys, did not put that long bolt on there for show, I bet there are some dudes out there that know of many other fergy implements that were designed to be top link hitched to that long bolt. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
