| Harry Ferguson Tractors Discussion Forum |
Topic: So the other day...
[Return to Forum]
| Author |
[Modern View]
| Bruce(OR)
01-05-2013 21:09:20
97.115.29.249
The wife goes out to her slightly modified Fergy TO-20. I am on the other side of the house and can only faintly her what is going on... Crank, crank, crank.... Vroom! chug, chug, chug, spu-u-u-tter, ugh.Crank, crank... Vroom! chug, chug, chug, spu-u-u-tter, ugh. Crank, crank, crank, crank, crank.... Vroom! chug, chug, spu-u-u-tter, ugh. By now I have gotten down there and notice the ign switch is not quite in the correct position. So, I try it. Crank, crank, crank,crank, crank.... chug, chug, chug, spu-u-u-tter, ugh. $%^%&***&^%^&!!! Pull the plugs. Yep! Wet and black. Where is my propane torch?? here is the striker, nearly worn out flint. here is the nozzle. Wrong nozzle, it"s busted. Fix it later cuz" I"m too cheap/lazy to toss it. Find another nozzle. Where in blazes is the can? Got sonme in the other shed. Somewhere. Okay found that. Fire it off and heat up some plugs. Burn off some gas, clean off some carbon. Good enough. it"s getting late. Screw the plugs in and try it again. Crank, crank, crank.... spu-u-u-tter, ugh. F%^%^&* IT! Another day or three... "When ya" gonna fix MY tractor?" Okay... pull the carb fuel filter. Not enough crud to make it not run. Clean it out anyway and install the brass fitting back into the carb. What"s this piece? Oh yeah dope! That"s the screen. Remove brass fitting and reinstall WITH the screen filter. How much gas is in this bomb? How about looking at the fuel guage? Huh? Okay, open the cap and verify. Yep! Out to lunch. Find the gas can and make magic. Wow, a little bit of liquid dead dinosaur works wonders. |
| Tony in Mass.
01-06-2013 09:39:16
76.127.225.182
Re: So the other day... in reply to Bruce(OR), 01-05-2013 21:09:20
| Propane torch??? What part of the 40 below Canadian Acrtic you live in??? Big Lots. Starter fluid $1.80 a can. Dries your mess, and when the girl fires up, and dies, and fires up and dies... THEN you can blame the gas guage.... I am scared to look in the tanks myself. They are always almost empty. Such a depressing thought.... did you see the thread about how I have to put gas in the one with the cab? |
| John(UK)
01-06-2013 08:53:21
79.76.240.215
| I think that has happened to us all at one time or another, but you get over it...lol...John(UK) |
| 2tractors
01-06-2013 06:24:16
207.144.5.133
| With wet plugs its easy for one to be lead down the wrong path. My tractors all have a ball valve with a see thru filter so there's only one screen to stop up but you can't just look down and see if the filter has gas and assu me thats not the problem as I have done in the past. |
| maxwell99
01-06-2013 05:33:09
208.78.250.177
| | Bruce, guess i am just old school, maybe it comes from always having old used equipment, but, before i try to start the old fergy, 1957, TO35 I always check the coolant, oil and fuel levels, 1/2 the time i also check the hyd/diff fluid level. then turn gas valve on and fire it up. the carb will leak fuel sometimes, if you leave the gas shutoff valve open. it can drain your tank, but you would know if that happen, as you will have a strong gas smell in the storage shed. good luck and always check your fuel level before starting up the old tractor, this practice will serve you well over the years, if you own an old fergy. |
| John Kruer
01-06-2013 05:03:30
199.193.183.1
| | That is what exactly happened to me Saturday morning. I had used the tractor Friday afternoon and left it outside in the cold since it usually sits under the leanto in the cold. Ran when I parked it.......I ran the battery down and then was jumping it with the F150. I sould have smelled gas for how much I was choking it. Looked in the tank and it was bone dry and not any in the reserve. Added gas and while trying to figure out how the gas evaporated the engine started right up as it always does. Huh, Where did my gas go to? Blamed it on the cheap gas these days and remembered that diesel fuel is too stupid to evaporate. Love to have a diesel in the future. |
| John Kruer
01-06-2013 05:06:09
199.193.183.1
Re: So the other day... in reply to John Kruer, 01-06-2013 05:03:30
| Also was reminded of the character "Carl Childers" from "Slingblade" when he said, "Aint got no gas in it". |
| s19438
01-06-2013 04:37:21
108.36.215.99
| been there, done that more times than i care to admit. |
| Inno
01-05-2013 22:13:27
64.229.157.71
| I did almost the exact same thing with my 202 about a month ago. I figured, it ran when I parked it there so it must have enough fuel to run..........wrong. Left it that day and came back a few days later with a can of gas. Whew! Immediately had back the tractor it was before........amazing what a little gas in the tank will do for ya! |
| ShadetreeRet
01-05-2013 21:35:54
184.4.21.191
| Yeah, we have all had days like that. Few years ago next door neighbor brought his riding mower to the house, wasn't running right, OK, I'll check it out soon as I can. Next day, fired it up, adjusted carb. ran OK for a minute and started acting up again. Tried two or three times, finally got it smoothed out, decided to ride it back to his house, (just couple hundred yards). Found out why it was so hard to get the carb adjusted, ran out of gas before I got there! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
