TractorLinks.com
Show Parts for Model:
Re: bracket
Jason S.
01-04-2013 10:56:10
It may not show it in the drawing but it is from the Ferguson book for that mower. Here is a pic of the bracket from Dearborn, it's the same bracket as the Ferguson and Dearborns part number was 141186
John(UK)
01-05-2013 02:55:25
 Re: bracket in reply to Jason S., 01-04-2013 10:56:10
Hi Jason, That bracket is not from the model of mower that was shown in the original post, that mower uses a standard stabilizer bracket. The bracket in your picture is for a different model and has more attachment points than necessary for this particular model. Sure it will fit but it isn't the original type. The only connection necessary on that bracket for the mower shown originally is the pin for the breakaway, which is the same that you would use for a stabilizer bar. It should be the opposite hand to the one shown as No.1 in your illustration.
I have attached the page from the mower parts list that shows the stabilizer brackets in the foreground and as you will see they are the standard brackets not the special one used on another model..John(UK)
Jason S.
01-05-2013 05:51:06
 Re: bracket in reply to John(UK), 01-05-2013 02:55:25
Ok, there is something I don"t understand about this. The pics that miner posted are from the 6A-E0-B20 manual and it shows the bracket with the ball. The mowers I have are 6A-EO-A20 mowers and they are made for the bracket with the ball. The pic you posted looks like a the pic from the Dearborn 14-1 owners manual. It doesn"t show that bracket with the ball, but the dealer parts book for that mower does show the bracket with the ball as well it shows the bracket with the ball for all the later model Dearborn mowers. Was this an oversight on Dearborns part in their manual? Or did they make a change at some point and some very early ones did not use that bracket while the Ferguson mowers did?
John(UK)
01-11-2013 08:01:54
 Re: bracket in reply to Jason S., 01-05-2013 05:51:06
Reply to the earlier post regarding the bracket under the rear Fender on a 6A-EO-A20 mower. I can't find that bracket at all on any of the Ferguson info that I have. This mower uses the Top Link with a Rack and chain to control the height but attached as normal to the Top Link Rocker. I did however find the bracket for the Top Link and the Stabilizer Bracket for under the Rear Fender in the pictures that were posted. Both items are from a Dearborn 14-73 mower and are used to attach it to 8N thro 600/800 tractors
The welded Top Link bracket was for a Ferguson Boom Crane and there are more than one type of these that I can see. I seem to remember that this type of bracket was used for the Crane when a Position Control kit was used with the crane. Without Position Control, the Crane could be a handful to control, but just what else was involved I have never been able to find out. It would appear that this was something made in the USA only. I Hope that helps to clear some of the query. Sorry for delay in replying, it took some searching to find this.John(UK)...fergusontractors@hotmail.com
John(UK)
01-11-2013 08:27:44
 Re: bracket in reply to John(UK), 01-11-2013 08:01:54
I should also have said that although the breakaway was very similar on the Dearborn Mower and the Ferguson, the Ferguson used the standard stabilizer bracket which was a simpler idea. There isn't any reason why the Dearborn mower would not fit the Ferguson using these attachments though from what I can see...John(UK)
John(UK)
01-05-2013 12:12:17
That picture is from the Massey-Ferguson 775 Book not the Dearborn one although I did check the Dearborn one as well and it was the same as I sent. None of my lists show that bracket with the ball, I thought at first it could be that it is an export version, but looking into it further they are the same. I will try to sort this out tomorrow...John(UK)
