TractorLinks.com
Show Parts for Model:
Re: preparing to split my te20 behind gearbox
John(UK)
01-02-2013 03:43:28
It doesn't"t take very much to jam the PTO shaft in the Pump. If you tighten the Clutch to prevent it slipping, there is no point in having the Clutch at all.No Need to remove the Top Cover. Split tractor cut PTO shaft at front of Pump as close as possible to Pump. Pull out PTO from rear without damaging the Pump if it is still tight. Be sure to carefully wash out the housing to get rid of all the metal when you cut the shaft. Drop The Pump and clean that too, DON"T start dismantling the Pump or you could make more work for yourself. Use NEW gaskets throughout when you re-assemble. If you need more info about this, email to fergusontractors@hotmail.com and I will send it to you...John(UK).....
