TractorLinks.com
Show Parts for Model:
Re: preparing to split my te20 behind gearbox
samn40
12-30-2012 01:30:40
It is real easy to split the tractor behind the gearbox. First make sure you have the front axle blocked from pivoting, a couple of wedges of wood will do. Put a floor jack under the gearbox and a trolley jack under the rear transmission housing and wheel the rear wheels backwards. To be honest if I am doing even a 100 o 200 series tractor I just slide a 3 foot piece of metal tubing over the PTO shaft and lean down on it as I wheel the rear half out. Even a tin oil drum will support the weight of these transmissions when out as they are so near in balance, makes for real easy alignment when going back together, the only downside is you need someone to place the prop under the trans when removed! Sam
