TractorLinks.com
Show Parts for Model:
Re: Attaching (Side) Hood Emblems?
Charles in Aus.
12-26-2012 23:46:59
Tom , it is found in both auto and construction fields. Best to go to a major bulk hardware to buy it as it should be cheaper from them. Neutral cure silicon compounds or caulking compounds are used on metal surfaces ,typically roofing iron. Ascetic cure silicon is used for masonry and glazing applications , the acid in it etches the surface and provides a key for the sealant , that same acid will literally eat metal away so it is important to get the right sort. Cheapest is fine , I have never found much difference in the more expensive sorts.
