| Author |
[Modern View]
| Jason S.
12-23-2012 11:58:15
174.252.151.168
Yes I really do use toilet bowl cleaner for carbs. It's $1.00 a bottle and makes that cast iron and brass look new. This one actually set with water in it it was rusty and scaly real bad.
| Inno
12-24-2012 07:45:13
70.49.136.91
Re: Toilet bowl cleaner for carbs. in reply to Jason S., 12-23-2012 11:58:15
| I'm intrigued, tell me more about your method. Do you put it in straight cleaner or mix with water? The after picture, did you have to do any brushing/scraping? I recently discovered carb soak but it's fairly pricey, if I could do much the same thing with toilet bowl cleaner that would be great. |
| Jason S.
12-24-2012 11:41:45
174.252.145.127
Re: Toilet bowl cleaner for carbs. in reply to Inno, 12-24-2012 07:45:13
| All I do is buy 4 or 5 squirt bottles of toilet bowl cleaner. I then pour all of it into a plastic container. Then I submerge the disassembled carb halves in the acid. You will see it start to bubble in a few minutes and after about 15 mins I pull them out and check them. Depending on how bad it is it may need a longer soak. After it is clean enough i rinse it really well with water. Then I wash it again with a degreaser and rinse and then I spray it with a little wd40 to prevent flash rust. The pics below are as it was before and then what it looked like after 15 mins in the acid and a rinse. It had no scraping or wire brushing done to it in the pics. That's straight out of the acid and a rinse. |
| KRK
12-24-2012 05:33:10
67.236.37.28
| Muriatic acid (hydrochloric) will remove rust from cast iron very well. Just a couple of precautions to follow.1. Don 't leave the part in the acid very long. Cast iron is porous and the acid is very active on cast iron unless the acid is inhibited. 2. Make sure once you are done to neutralize the acid on the part in a baking soda/water solution to. Happy Cleaning! |
| s19438
12-23-2012 13:41:20
108.36.215.99
| have you ever used the dishwasher to wash parts or cook fish? |
| lyle niemi
12-23-2012 12:31:54
209.91.107.238
| ow long did you have to leave it soak for? |
| Jason S.
12-23-2012 12:37:47
174.252.151.168
Re: Toilet bowl cleaner for carbs. in reply to lyle niemi, 12-23-2012 12:31:54
| lyle niemi
12-23-2012 12:40:00
209.91.107.238
Re: Toilet bowl cleaner for carbs. in reply to Jason S., 12-23-2012 12:37:47
| Im gonna have to try that, any special brand to use??? |
| Jason S.
12-23-2012 13:07:41
174.252.151.168
Re: Toilet bowl cleaner for carbs. in reply to lyle niemi, 12-23-2012 12:40:00
| No...I usually buy the generic brand. It will say either 16% or 20% hydrochloric acid. Which means make sure there isn't any aluminum on your carb or you will have a bad chemical reaction,it will foam up and cook the aluminum. I did another one just a second ago and took before and after pics I'll post. It needed a little longer to soak when I took it out but you can see how well it works. |
| Jason S.
12-23-2012 13:16:27
174.252.151.168
Re: Toilet bowl cleaner for carbs. in reply to Jason S., 12-23-2012 13:07:41
| Quoting Removed, click Modern View to see
Before
After 15 mins
| s19438
12-23-2012 12:05:22
108.36.215.99
| TB cleaner, carb. pics and a pizza box. does it get any better? |
| Jason S.
12-23-2012 12:16:16
174.252.151.168
Re: Toilet bowl cleaner for carbs. in reply to s19438, 12-23-2012 12:05:22
| Yes it does, I'm rebuilding that one on the kitchen countertop...lol. It's too cold outside. |
