| Harry Ferguson Tractors Discussion Forum |
Topic: Re: How to buy a rebuilt motor update 2- question
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Jason S.
12-18-2012 16:58:29
174.228.82.167
When it breaks loose the rings will scrape a lot of the rust off of the walls and push it to the top of the cylinder where it can be wiped out if the head is off. I usually take a cylinder hone and hone the tops of the cylinder walls so it removes some of the rust before i try to break it loose.Will it be an oil burner? That depends on how bad the cylinder walls are pitted and the rings are worn. If I could break it loose and crank it that"s what I would do. That way you can check oil pressure, listen for knocks, check the hydraulics and etc... |
| Jason S.
12-18-2012 17:10:23
174.228.82.167
Re: How to buy a rebuilt motor update 2- question in reply to Jason S., 12-18-2012 16:58:29
| I've never tried air pressure, I've even heard of people pumping the cylinders full of grease and the hydraulic pressure breaking them loose but I would not ever try that. Personally I would remove the head and soak the cylinders some more and then take a block of wood and a hammer and tap on the tops of the pistons. Then take a breaker bar and socket and put on the bolt on the crankshaft pulley and see if it moves any. If it doesn't repeat the process. Just keep working at it. I don't rock the tractors when the engine it stuck because a lot of the time the clutch will slip before it break the engine loose. Especially if the clutch is worn. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
